跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Display not anchored horizontally/vertically
Last night I changed the battery and video display on my iPod Video 30 GB. After powering back up, the display lights up and has no pixel issues, but the display is not "anchored" horizontally or vertically. Sometimes the display is pushed to the right, so that the right side of the normal display is actually on the left side. The same goes for the vertical, and sometime it does both at the same time.
For example, the ">" which normally appears on the right side of the main menu may actually show up on the left side of the screen, or the "Music" may be at the middle or bottom of the screen, rather than the top.
It moves around, so it is not always displaying the same way.
Did I mess up the display connection?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
dbwingnut, first you have to make sure that the ribbon cable is properly (straight) seated in the connector. Then you have to be sure that you have a 5th gen display. If all that is okay, then I would suggest to return the display to the vendor for an exchange.
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your reply. I tried to re-connect the video display, but now it only displays all white. Then I reconnected the old video display, and it does the same thing. Even if I re-set the iPod (by toggling the "Hold" button, then holding the center + Menu buttons), it still doesn't show anything. It won't let me shut it off or do anything with it now.
完成的
添加一条评论
添加你的答案
dbwingnut 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 11
过去 30 天: 14
总计 77
