跳转到主内容
加入维修社区 - 创建账户
1.5 GHz Core Solo、1.66 或 1.83 GHz Core Duo,或 1.83 或 2 GHz Core 2 Duo 处理器。 本页面涵盖了从 2006 年初到 2007 年中的首批基于 Intel 处理器的 Mac mini 机型。
No Sound from Mac Mini!
I have a new problem that involves no sound coming out of the Mac Mini's speakers. When i received my Mini from the seller there was a gap to the rear of the unit as the party before me did not reassembly the top cover all the way. I gave it back to have the cover fitted correctly and now after powering on the unit I recognise that there is no sound, and plugged in some external speakers and got sound for just about 2mins then a lot of static. I then purchease a putty knife filed the edges and opened the case, but I found nothing that seemed like it was out of placeso I reassembeled.
Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
已选择的解决方案
sounds like a problem with the audio board
maybe you should open the mini again and look if there is something odd with the board or the connection
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
I had the same problem with a Core Solo machine. Turns out the people who installed some RAM (this was before I discovered ifixit) had not properly seated the ZIF cable in its socket.
Steps 7 and 8 in the Audio Board install (Mac mini A1176 型号音频板更换) are where the solution lies.
There is a painted line on the ZIF cable. Before you close the cable lock, make sure the cable is fully inserted - the painted line will be about 1mm above and parallel to the top of the socket. Push down the clip and all should be well.
这个答案有帮助吗?
得分 5
1条评论:
this was it for me, SSD was installed by previous owner and the ZIF cable was re-seated BEHIND the actual connecter! Phew :)
由完成的
添加一条评论
I had the same problem with my MAC MINI A1176 Audio Board so instead of opening the case again I have scarified 1 USB socket and inserted a USB audio divice and it works just fine.
a internal can cost a 30 $ on eBAY but a USB dive can cost you 5 $.
这个答案有帮助吗?
得分 2
添加一条评论
Thanks Gary, this was exactly it!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Robert Antoine 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 25
总计 12,321
