跳转到主内容
戴尔所制造的笔记本电脑。
3028 个问题 查看全部
5 beeps with a black screen
Mine is a Dell inspiron and it's doing 5 beeps with a black screen... can you help me with this one?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
hullo i have a dell laptop with intel i core 3 prcocessor, power enters but it doesn't light on screen and i account 5 beeps in speakers and continues beeping until i put off the power whats the solution
完成的
添加一条评论
3个答案
已选择的解决方案
kasie, it will help if you give us the exact model of your Dell. The POST diagnostic beeps for most Dell laptops :
One= Possible system board failure —BIOS ROM checksum failure
Two= No RAM detected NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three= Possible system board failure — Chipset error
Four= RAM read/write failure
Five= Real Time Clock failure
Six= Video card or chip failure
Seven= Processor failure
Eight= Display failure
So, there could be a problem either with the CMOS battery or the motherboard. Hope this helps, good luck.
这个答案有帮助吗?
得分 4
2条评论:
olturky03 Thank You So much it helped me
完成的
thank you
very helpful
in my case 5 beeps ( the rtc )
完成的
添加一条评论
This can either be a Ram problem or some other hardware malfunction. All you need to do is take your Ram modules apart one by one and then try plug in them back one by one by powering on your PC each time. In this way you will be able to confirm that whether its the ram or any other built in hardware problem. Also check if your motherboard`s backup battery is working fine.
这个答案有帮助吗?
得分 1
4条评论:
Seems that swapping RAM worked for my Dell Inspiron 5520. Thanks!
完成的
He said 5 beeps. That means cmos, not RAM!!!
完成的
I was stuck with those 5 (five, not three, not four, I swear five) beeps. Replaced CMOS battery twice, didn't work. Tested batteries with a multimeter, voltage was OK. So? With the same CMOS battery installed, I swapped the memory banks and...magical, the inspiron POSTed correctly. Strange, but if you read what david chase wrote up, this can be either a CMOS or a RAM problem. In my case, the RAM was the culprit.
完成的
The 5 Beeps is also RAM. Mine happened after I installed a new fan when this happened to me. I was about to give up when I saw this post. Re-seating the RAM got rid of the 5 beeps and everything is now working great.
完成的
添加一条评论
It gave me 5 beeps at first, so I removed the CMOS twice. The beeps continued until I removed the ram then placed it back but I still don't have any display.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kasie 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 49
过去 30 天: 208
总计 19,495
