跳转到主内容
加入维修社区 - 创建账户
华硕生产的笔记本电脑的维修指南和拆解信息。
How to enable my touchpad
I disabled the touchpad some time ago, and now I don't know how to enable it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 102
18条评论
thanks for all the advises but they didn't work maybe because mine is a toshiba but can fixed it out by clicking on the start button then just search mouse, then from the result just click the mouse setting after that then click on the device settings then finally you can see a small box under the work device the tab on the enable button then you can click again on the apply & ok button that is where I can enable my touchpad
thanks for your time hope this is can assist you
由完成的
Windows 10: Does anyone at ASUS know or care? This has been going on for laptop since December 2015.
由完成的
At a same time my asus x554l touchpad and mouse doesnt work. Please help fix this.
由完成的
Hi @aguerosergio919,
Use a USB mouse so that you can install the latest Asus ATK package and Smart Gesture drivers for your laptop to get your touchpad working again.
Here is a link to the latest drivers.
Install the ATK package FIRST and then the Smart Gesture.
Take notice of the NOTES near the top of the page as to how to install the drivers.
Do not be tempted to install the other drivers from this page. Solve one problem at a time. If it isn't broken, don't fix it.
http://ivanrf.com/en/latest-asus-drivers...
由完成的
OMFG I SPENT THE LAST 2 HOURS TRYING TO REPAIR DRIVERS and now i pressed Fn + F7 and all fixed. I want to kms..
由完成的
显示更多的13条评论
添加一条评论
13个答案
已选择的解决方案
I just had the same problem. The silly cat disabled mine! The key combination for mine was Fn + F9. It worked perfectly.
这个答案有帮助吗?
得分 65
46条评论:
OH THANK YOU KIM ur right
由完成的
hallelujah! thank you so much!!!!!
由完成的
That worked! ugh and I was so frustrated... thank you so much!!
由完成的
worked, thank you ur awesome
由完成的
you are my hero <3
由完成的
显示更多的41条评论
添加一条评论
Hello Cindy ,
First of all Restart your computer after restarting the computer it will not gonna be work then do these steps
1- Enable your touchpad:-
If your laptop has a function key that enables/disables the touchpad. by pressing it Fn key + F5, Fn + F6 .
2- Touchpad devices enable or disable-
:-Click on start
:-Click on settings
:-Go to the devices
:-Click on mouse and touchpad
:-scroll down
:-Click on additional mouse go to mouse properties.
:-Click on devices.
:-See there if touch pad is disabled then select it on enable mode.restart the computer
If it does not work then visit this articale fix the touchpad related problem step by step
3-Update your drivers-
.Press windows key + R key together.
.Type in the run dialog box- devmgmt.msc.
.Enter and go to Mice and other pointing devices.
.Find your touchpad driver and Right-click on your touchpad driver and Click Update Driver Software.
if nothing works than -
.Go to device manager again.
.Un-install your touch pad driver – By right click on your touchpad's driver or press windows key + R key.
.Type appwiz.cpl in run box.
.Un-install your driver.
.Download your touchpad driver by your laptop brand name and model no. through manufacturer site.
这个答案有帮助吗?
得分 17
5条评论:
This help me as I cannot use the function keys because have different keyboard features! Thank you so much!
由完成的
thank you your my hero!!!!!!
由完成的
keneth I love your communication
由完成的
your technic is really working..I am very impressed your technic
由完成的
omg u made me cryyyy! i was an idiot for not checking the settings smh! thank you so musch!
由完成的
添加一条评论
It seems like you touch-pad has been disabled from your keyboard. You can check your keys from F1 to F12 and see where is the touch-pad icon on which key. So all you need to do is to hold that key by pressing Fn key. In this way your touch-pad will be enabled.
这个答案有帮助吗?
得分 7
11条评论:
Thank you very much
由完成的
Thank you very much, you are right
由完成的
Thanks also, i also looking for this answer.
由完成的
THANK YOU SO MUCH!!! <3333 Mine was Fn+f7!!
由完成的
Some work, but not fnf9 to disable the touchpad!
由完成的
显示更多的6条评论
添加一条评论
it is usually the fn + f9 key to fix it...
i made the mistake last time of pressing the fn + f9 too many times and there was a lot of "static energy build up in the motherboard..."
I called the Asus support and this is how they fixed it
first they had me shut the laptop all the way down
then I held the power off button for thirty seconds(to remove static energy from motherboard)
then I turned laptop on again by pressing powerbutton
it took me to a blue screen
I was advised to press f9 key(optimized defaults) and press yes
then I was advised to press f10 to save configuration and press yes
then the laptop started back up
my touchpad still wasn't working but I was advised to press the fn button down and then tap f9 key one more time and... voila!!
hopefully that helps
这个答案有帮助吗?
得分 7
3条评论:
Turning it off and holding the power button for thirty seconds, then restarting worked.took some time to boot up but it worked.
由完成的
Thanks for sharing your experience, It was really helpful.
由完成的
It worked. Thank u so much 😊
由完成的
添加一条评论
hello mate
I just tried and it worked the actual way is press fn+left touchpad button(left click)+touch pad function key.
这个答案有帮助吗?
得分 4
5条评论:
YESSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!! For the ASUS Transformer, this is IT! !Thank you! What a pain in the butt. I am not a fan of this damned computer. Thank you, though. :)
由完成的
OMG THANK YOU. I have the ASUS F551M and this worked for me.
由完成的
thank you!!!it helped alot!!!thought i have to bring this to the shop..
由完成的
Not with my Asus Laptop R512c
由完成的
Tried everything else including re-installation of drivers etc. This works for ASUS x552c. Many thanks to you Faisal
由完成的
添加一条评论
I had this issue of my touchpad not working (no cursor or ability to click anything). The keyboard shortcut didn't work and I tried updating the driver but it didn't work either. What did work: I opened "Device Manager". I went to view and hit "Show hidden devices". The grayed out devices are the ones not functioning. Under human interface devices a few weren't working. The driver for "Input configuration device" was the root problem. I held it and hit the option to uninstall it and restarted my computer. The computer automatically re-installed the driver and everything works!
这个答案有帮助吗?
得分 4
2条评论:
That worked perfectly. Thanks!
由完成的
This one is really worked! Thank youu
由完成的
添加一条评论
The above did not help, this is how I solved it on my ASUS laptop
Look at the tray, I did not have ASUS Smart Gesture Icon.
So I manually started Program Files /Asus Smart Gesture/ AdTPCenter/x64/AsusTPLauncher.exe
After that the icon showed in the tray and the touch pad started wording - no additional buttons were needed. Maybe after that Fn+F9 would also work.
Cheers
这个答案有帮助吗?
得分 2
添加一条评论
Good morning!!!!!!!!!!!!!
From all the advises mention none of them is working for my problem, maybe because mine is a different brand which is a TOSHIBA, but I had already fixed it by following these steps;
1. click the start button
2. type the word mouse in the searching box
3. click on the change mouse setting
4. click on the device setting button
5. click on the enable button below the small box
6. click on the APPLY button
7. click on the OK button
Then finally your touchpad will start working again
I hope these steps will help you out with your problem
这个答案有帮助吗?
得分 2
添加一条评论
i have a problem…the cursor cannot be found during installation of windows 7 o my asus r540s?.. even i used a portable mouse still the cursor cannot be seen…whats wrong?.. i need it.. thanks
这个答案有帮助吗?
得分 2
添加一条评论
You accidentally turned off touchpad, no option to turn it back on.
I did the same thing, and nothing seemed to work. What finally worked was I opened device manager - human interface devices. It said the touchpad was working properly.
I did a update driver - find driver on internet. When the new driver installed, I found a window with the option to turn on the touchpad, similar to the one that turned it off.
It worked
Harry
这个答案有帮助吗?
得分 1
添加一条评论
So my keyboard wasn’t working already I’m aware that it’s a driver issue but while trying to fix that I’ve inadvertently disabled my touch pad as well any ideas? I’m literally staring at the enable touch pad function in armoury crate but can’t select anything
这个答案有帮助吗?
得分 0
添加一条评论
Mine was Asus X555B, and the way I fixed it was by clicking the Windows button -> Search and open “Device Manager” -> Collapse “Mice and other pointing devices” -> Open ASUS Touchpad -> Navigate to the driver tab -> Uninstall Device -> Uninstall (WITHOUT Checking up the option to delete driver) -> And finally restart the laptop.
The driver will be reinstalled with touchpad enabled
这个答案有帮助吗?
得分 0
添加一条评论
When touchpad not working on the Asus laptop, you should check the windows settings. most probably, windows settings are incorrect. that's why touchpad is not responding on the windows laptop. so you need to make the following changes into the asus laptop.
  1. First of all, you need to make sure that the touchpad is enabled on the windows laptop. it is not disabled.
  2. Now go to the device manager, here you need to update the windows driver. also, you need to update the settings on your laptop.
  3. sometimes, Asus touchpad won't respond because of the settings issue. so you need to remove the driver. now re-add the driver. after that your touchpad will start working fine.
  4. Let's update the windows on your asus laptop.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cindy 将永远感激不已
浏览统计数据:
过去 24 小时: 19
过去 7 天: 202
过去 30 天: 931
总计 667,309
