跳转到主内容
24英寸显示器,内置iSight 摄像头,麦克风和扬声器。 1920*1200分辨率。 发布于2008年10月 型号为A1267
84 个问题 查看全部
stays black but the lcd is working
got the same problem, at the 27 inch one.... it stays black but the lcd is working you can see it when you use a torch or the led of your iphone....
for a quarter second it appears the light and picture in the screen but then its gone....
usb and charging is working....
its only the light not the lcd
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
4条评论
What happened just prior to this? Any power surge, fluid exposure? Since the LCD is working but the screen stays dark, we know that your backlight is out
完成的
I am having this problem too with the same model, did you find a solution?
完成的
Are there any news here, yet?
完成的
@mail79, as you can see by the original answer, the missing information was never given. If you have similar issues with your device, I suggest you ask your own question. give all the information needed to identify your device and describe the symptoms as concise as possible :-)
完成的
添加一条评论
1个答案
最有帮助的答案
Sounds like an inverter board issue to me. Would you give us your specific model number?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sebastian Jund 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 1,399
