跳转到主内容
加入维修社区 - 创建账户
关于第二代 Apple iPad Wi-Fi 版更新机型的维修指南、拆解和故障排除信息,有 16、32 或 64 GB 存储容量可选。于 2012 年 3 月发布。可通过型号 A1395 和 EMC 2560 识别。它采用了更小的处理器核心和更新的内部结构。维修时需要使用加热和小心撬开。
Camera Shutter Stuck After Screen Replacement
I recently replaced a broken screen and now the back camera shutter is stuck. I tried a new back camera, but that didn't fix it. I also tried a hard reset, but that also didn't work. Ay ideas how to resolve the issue? Could the connection not be right?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
I figured it out. I removed the camera, erased and reset the iPad, ran the set up process, and then reinstalled the camera. Then everything worked.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Some loose connectors between cameras and the logic board. Reseat every connector in between, especially the front camera which is easy to come off
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Boss77 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 492
