跳转到主内容
Help to identify burned capacitor on mainboard
Hello
Looking at my father-in-Laws MacBook Pro unibody A1278 unibody. He accidently spilled cofee onto the keyboard.
The computer seems to run just fine now 1 month later, however the backlit on the keyboard is gone and many keys on the keyboard are not working correctly.
It is a 820-2936b board.
On the mainboard a single capacitor is burned, can you help me to identify it please:
I managed to find this picture showing the capacitor in your guides, but cannot read the text:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Stokholm - That component is a SMD Capacitor not an IC.
完成的
添加一条评论
1个答案
已选择的解决方案
Stokholm, that is reference designator C6603 and is a 100UF 20% 6.3V TANT capacitor. The case is a A L1 and something like this or on here should work. the capacitor is not part of your keyboard backlight, but of the Speaker Amp circuit. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
6条评论:
Thank you very much for the detailed answer.
I will get the keyboard and capacitor replaced, thanks to you it is possible to install the correct one.
完成的
Can I use a size B (3528) with the same specs instead of the size A (3216) - there is enough space on the board.
完成的
It might be possible, but make sure that the cap will meet the solder pads on the board. If it does, you can most certainly use it. Thank you for accepting my answer and best of luck to you.
完成的
I received a new keyboard and backlight, it all work very well now. I haven't replaced the cap yet, as I am still waiting for it to be delivered. Can it be dangerous to use it with the burned cap?
完成的
Since it is already burned out your circuit already has failed, so that is no longer a danger. I would however replace it as soon as you can:-)
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Stokholm 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 959
