跳转到主内容
加入维修社区 - 创建账户
Component identification liquid damage
Can anyone help identify these 2 components,(see red circle) the macbook suffered liquid damage and after cleaning i noticed these 2 look burnt, i think they are resistors. Macbook powers up, fans run, but no screen display, or beep on startup
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
I did add images, dont know why they didnt work, will try again
完成的
添加一条评论
1个答案
已选择的解决方案
syoung6500, I think I located the components. Please check the attached image to make sure those are the ones in question. If they are, then those are two capacitors, C7525 and C7526 respectively. Both are 10UF 10% 16V 0805 X5R-CERM and are available at places like this Hope this helps, good luck.
这个答案有帮助吗?
得分 2
2条评论:
Thanks very much for the quick reply, ive ordered from the link you gave. Im not sure if this will fix it but i thought ive got nothing to lose by trying.
How do you find out which component is which? if you dont mind telling :)
完成的
:-) Having the right right tools and the right schematics helps a lot:-) It used to be easier when there were no SMD components and all the resistors and caps were color coded. Now you pretty much will need schematic to repair on a board level. Best of luck to you and your repair. Hope you get it fixed. Keep us informed.
完成的
添加一条评论
添加你的答案
syoung6500 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 259
