跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Logic Board Replacement Model Number
My first ipod classic i had had the battery connector snap off the logic board. I went ahead and bought another broken ipod classic off ebay, in hopes for the easy fix of the battery. When it came in the mail, I inspected it then opened it up to replace the battery with a new ipod classic battery i picked up.
However, once I placed the cable into the connector, it immediately started to heat up and produce a smell like it was melting. I quickly took it out of the connector (carefully) and began looking around for answers. Its possible that the logic board may be shot, and as I was looking online for one, I notice that there are two model numbers for the same device, 820-1765-A (which is the one I have) and 820-1975-A.
Can I use either one, or do I need to use the one that came with the original ipod for replacement?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Steven, 820-1975 is the iPod Video 5.5 gen motherboard. It should work with the 30gb and the 80gb iPod Video 5.5. The 820-1975-A board can be used to replace the older board, but it may require you to format the hard drive. The "started to heat up and produce a smell like it was melting." does not have anything to do with that. Double check the battery connector on the board as well as the battery. It is possible that either the battery connector has issues (very common for this model) or your battery. Make sure that you installed the battery the right way ;-)
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the help :)
I did go back and install the new battery into the ipod, slightly wary for the same problem. When I connected it, I felt no heat and smelt no smell from the connector port. Guess I placed the cable wrong or not all the way into the connector.
Thanks again for the info!
完成的
you are welcome, best of luck to you.
完成的
添加一条评论
添加你的答案
Steven 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 1,984
