跳转到主内容
加入维修社区 - 创建账户
Seagate 的外置存储选项,通常通过 USB 连接,有多种存储容量和外形规格可选。
Why is it not detected?
When I plug in the computer USB port the drive is not detected; the green led blinks and I can hear weak continuous beeps. It is a Seagate 750GB external hard drive.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论:
I have a Seagate 1.4TB external drive with a dedicated power cord; and mine also isn't being detected. Tried it unsuccessfully on 4 machines: Windows XP, Linux Ubuntu, an Apple Mac and a Toshiba Android tablet. No go. It makes whirring sounds for a few seconds then quits.
由完成的
添加一条评论
2个答案
Assuming the drive is ok (have you tested it on another computer) it might be, that it demands too much current from the USB port - had this with an older FSC drive (I think with a Seagate or WD drive builtin).
Regards, Stone
这个答案有帮助吗?
得分 0
添加一条评论
External HD is composed by two parts: a controller and a classic HD. I would try to open it and conect the HD directly to the mainboard with the right interface (sata or parallel) ... if it works by anothe case/controller (very cheap) if it's not recognised ... it's above my knowledge ....
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ratish 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 14
总计 907
