跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
How to fix an iPod Touch when dropped in the sea/water?
When i was at the beach i had my iPod touch 4G in my pocket with 20 Euros ( because i was in France for the week ) and i accidentally forgot to put it in my bag with all my other stuff and as i found out it was cold, and wet so i rushed to my bag to get my towel and left in the blazing sun but nothing happened? What could i do because my grandparents do not have any rice in the house and i am leaving on the next day ( Wed 14th August 2013 ). Should i wait till i get home to put it in rice or just try to buy some rice and leave it overnight to dry a bit and bring it with me to the ferry with the iPod touch in the container?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I was at the beach in samoa im back at home in auizzie i was unloding my things on my chair and forgot it was in my pocit i only noticed when i felt a bumb on my left thigh a emditly rememberd it was in my pocet ran straty away and put my iopd on a towl and rapd it up i could do nothing to my ipod touch 4g becuse in my house in samoa we have little so 2 weeks later still dosent work and still cant find solution please HELP
完成的
添加一条评论
2个答案
已选择的解决方案
Julien Leost, Rice is a great first aid, but it will not fix anything. The saltwater is corrosive and your will run into trouble at a later point, if you do not clean it properly. Disassemble your iPod using these guides. Remove your logic board and clean it with sterile water first, do not use tap water. Then clean it a few times with 90%+ isopropyl alcohol and a soft brush. Clean all the connectors and cables the same way. Then replace the battery and reassemble your iPod, re-evaluate for any further, more specific damage. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
First, do not try to turn it on it could kill it. Yes, you should buy rice and leave it in it for a couple of days, it may fix it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Julien Leost 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 2,171
