跳转到主内容
Repair guides and support for many cameras in the PowerShot Line.
20 个问题 查看全部
Service Manuals for Canon Powershot cameras?
Does anyone have a source for Service Manuals for Canon Powershot cameras? I have many working Powershot models but there is dust INSIDE the lens/ccd and I would love to take it apart to clean it. I need service guides or take-apart instructions for Powershot S100, S110, S200, SD400, SD600, SD780, SD940, SD1000, SD1100, and SD1200.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
If you do get them all apart, I would encourage you to document the process. http://www.ifixit.com/Guide/new
完成的
添加一条评论
7个答案
已选择的解决方案
I think many people have their sources - but i see there a slightly legality issue - so the only answer i would give is: "google it"
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
I don't have a service manual for you, however I've taken apart my Powershot S500 several times, including opening the lens/sensor assembly to successfully clean dust on the sensor.
I documented it in this teardown report here on ifixit. From other Powershot cameras I have seen and poked around with, the construction of others is very similar so even if you're wanting to do this with a different model, you may find my photos instructive.
I also notice there are some additional repair guides for other Canon models here on ifixit now - take a look at those also.
if you are handy with taking apart things and handling tiny screws and delicate ribbon cables, you may be able to take apart your camera without a service manual. basically just take it apart one screw at a time, save and label where the screws go, and perhaps take photos along the way (that's how my teardown photos came about). then reverse the process when done. good luck!
这个答案有帮助吗?
得分 4
添加一条评论
Here's a link to the repair manuals for the Canon Powershot - Pro1, S10, S45, A70, A95, IXUS II/SD100, it's not everything you want but should give you a very good idea of how they work: http://qman.fotokala.ee/
这个答案有帮助吗?
得分 2
7条评论:
This link is dead - the domain is for sale.
完成的
@johncc Jon the question is 9 years old.
完成的
Hi, Mayer. Not criticizing you! Just trying to save time (and hope) for someone else. I'm still looking for a guide for the SX170...
完成的
Mayer, I already received more than 75 identical notices of your original comment by mail. What's happening?
完成的
@johncc Looks like a glitch in the iFixit mail system. I will notify them to stop it, may take till Monday.
https://meta.ifixit.com/Answers/View/139...
完成的
显示更多的2条评论
添加一条评论
Google the following: "POWER SHOT S400 - IXUS 400.pdf" (without the quotes). You will find the parts list that gives you an idea on how to dismantle it.
I found the document here: http://www.micro-tools.net/pdf/Canon/POW...
jflarin
这个答案有帮助吗?
得分 0
添加一条评论
Try to find here http://service.gex-bbs.ru/canon_camera.
这个答案有帮助吗?
得分 0
1条评论:
Gives a 404 error
完成的
添加一条评论
Our Canon Camera repair manual section is growing constantly. We have quite a few PowerShot models already, and we get more every few months.
这个答案有帮助吗?
得分 0
添加一条评论
Look service manuals here: http://www.smpcshop.com/Canon-Cameras-Se...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rei Yoshioka 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 33
总计 25,545
