跳转到主内容
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
need to replace the motherboard
I have mini computer ASUS with serial number is SN: 970AAS36893 and the PC 1005HA-PUIX-BK need to replace the motherboard is that ok
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
Another way to replace the motherboard is you can download the service manual to replace it by yourself or you can also follow some online video tutorial for DIY.
完成的
添加一条评论
1个答案
abdullah alshalabi, this guide is pretty close to the motherboard. Follow it and then remove the board. Or you can check this video, which shows you even more. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
abdullah alshalabi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 288
