跳转到主内容
一个广泛的电子产品维修指南,从家和汽车音响到计算器。
26497 个问题 查看全部
Can I charge a rechargable battery by keep put voltage?
it's a long story.
i heard 3.7V Li-Ion rechargable battery has 4.2V at full charged.
but i have a problem with making full charge detect and cutting off charge circuit in my situation.
so i think put 4.1V to the battery all the time makes charging but not over-charging it.
is this possible idea?
thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Anonymous, you can do that if you develop a proper circuit. You will need to provide a feedback circuit for the battery to manage the power to it. You can not just continuously supply 4.1V to the battery. I would suggest that you repair whatever device this goes with.
这个答案有帮助吗?
得分 2
1条评论:
Most Li-ion chargers have two states of charge a low voltage and a high. Then often have a feedback circuit to know when the voltage & temperature has hit a threshold so as not to over charge the battery as doing so will cause it to explode and start a fire. I agree here with OT as you could damage the battery or worse yet start a fire.
完成的
添加一条评论
添加你的答案
Anonymous 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 91
