跳转到主内容
加入维修社区 - 创建账户
2.26 or 2.4 GHz / White plastic unibody enclosure
Keyboard ZIF Connector Pinout
I'm looking to determine which contact on the keyboard connection on the A1342 is for the 'on' switch function (or any other contacts on the logic board will do). I'm fairly certain this pin is active low (pressed goes to ground), yes?
Thanks, Keith
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi,
I am searching for the pinout of 34 pin ffc cable of laptop keyboard.
Thanks & Regards,
Yash Kishore
完成的
添加一条评论
3个答案
已选择的解决方案
Keith55555, looks like pin 5 is the one you are looking for. Hope this helps, good luck.
这个答案有帮助吗?
得分 4
3条评论:
Looks good O.T. Appreciate it. -Keith
完成的
Anytime ;-) Thanks for accepting my answer.
完成的
Do you have a keyboard pin out from an A1502?
完成的
添加一条评论
It boggles my mind that this little picture was so hard to find on the INTERNET it is almost like these companies making laptop er um notebooks these days dont want us knowing how they work or operate.
That way we cannot ever comprehend enough to troubleshoot or fix them when something goes wrong. Or they just dont want us realizing that they are built to fail in so many hours. Grrrrrr
这个答案有帮助吗?
得分 0
添加一条评论
I measured the resistance in Ohm of those pins to ground, both keyboard plugged in and (plugged out)
  1. 336 Ω (336 Ω)
  2. 336 Ω (336 Ω)
  3. 337 Ω (336 Ω)
  4. 209 Ω (208 Ω)
  5. 1745 Ω (1745 Ω)
  6. 444 Ω (1.9 MΩ)
  7. 368 Ω (468 Ω)
  8. 365 Ω (1.92 MΩ)
  9. 440 Ω (439 Ω)
  10. 372 Ω (371 Ω)
  11. 369 Ω (369 Ω)
  12. 381 Ω (381 Ω)
  13. 282 Ω (444 Ω)
  14. 477 Ω (477 Ω)
  15. 443 Ω (442 Ω)
  16. 442 Ω (441 Ω)
  17. 442 Ω(441 Ω)
  18. 444 Ω (443 Ω)
  19. 381 Ω (381 Ω)
  20. 441 Ω (440 Ω)
  21. 440 Ω (440 Ω)
  22. 445 Ω (445 Ω)
  23. 442 Ω (441Ω)
  24. 443 Ω (442 Ω)
  25. 440 Ω (440 Ω)
  26. 448 Ω (448 Ω)
  27. 444 Ω (443 Ω)
  28. 444 Ω (444 Ω)
  29. 0 Ω (0 Ω)
  30. 230 Ω (229 Ω)
measured on an MacBook Pro A1502
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keith55555 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 45
总计 7,165
