跳转到主内容
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
24 个问题 查看全部
Replacing motherboard in Asus Eee PC 1005HA
Hello, after few years my eee pc 1005HA is broke. I send it to IT shop for repair. they said some parts on motherboard has died. They said i need to replace the motherboard. After few search on the web, i found that the are 3 different laptop of this model. Question is. Does all motherboard of this type of laptops can fit ? I dont care about the differents in processors or bluetooth. I just need to know does they fit in the body of other models ? Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
p1nky, the difference is usually just the processor and other on-board architecture, while maintaining the same footprint. Always check with the vendor to make sure that you come as close to what you currently have. This will show you how to change the motherboard. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
p1nky 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 2,542
