跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
rice trick with iPhone?
because of a slip and slide incident my iphone speakers dont work at all. but heres the odd thing my iphone never shut off after it happen so i turned it off and put it in a bag of rice. other than the speaker it works perfectly. i just cant call anyone..... the phone had a case mate case on it and a screen protector. i only sent one text on it after it happened, will the rice trick still work? i didnt turn it off until after i got home
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Anna, not sure what the "slip and slide incident" entailed but if it with submerged in any liquid, the "rice trick" is only basic fist aid. It will not fix your phone nor will it prevent any corrosion. For that you will have to disassemble your phone and clean everything with 90%+ isopropyl alcohol. When you say that your speaker does not work, try a head set and see if that makes a difference.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Anna 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 454
