跳转到主内容
加入维修社区 - 创建账户
Suzuki FA50 助力车维修与故障排除信息。
Question about the fuel system?
Does the system use an oil injection device, or does the fuel have to be pre-mixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
已选择的解决方案
The fa50 has a oil injection system
CLICK
but older systems can be problematic - so pre-mixed could be an option
这个答案有帮助吗?
得分 7
添加一条评论
As Markus already answered, the FA50 has an oil injection system. However, several users on Moped Army advise to bypass the oil injection system and just premix the fuel -- it will supposedly regain a bit of power lost from powering the pump.
I am looking into creating a guide for this procedure, but it will be a while before I get a chance to sit down and figure it out.
这个答案有帮助吗?
得分 3
添加一条评论
Het is mogelijk benzine en Olie 2takt vooraf gemengd te vullen in de benzinetank ? Gedaan En Wat Met De olieinjectie ?
这个答案有帮助吗?
得分 0
1条评论:
well, my dutch is pretty rusty - but i'll try to answer that.
as miroslav stated. there are users on mopedarmy.com who are bypassing the oil injection. technically it should not be a huge problem - it's some kind of normal on other 2 stroke bikes (aprilia af1, rd350 and so on). but maybe mirsolav can tell you more about that.
Miroslav zoals gezegd, zijn er mopedarmy.com gebruiker op de pre-gemengde benzinetank en ontkoppel de olie-injectie
het is een soort van normaal op andere 2 takt motoren (Aprilia AF1, rd350, enzovoort). maar misschien mirsolav kan u meer vertellen over dat.
i hope that this is halfway understandable. i had a girlfrind who's mother was from the netherlands - so my duch is not the best - reading - no problem, but writing or speaking - aaargh -
由完成的 分享
添加一条评论
I just bought two 1985 fa50s. Has old gas that needs to be drained. I had the same question regarding the mix. Also, does these babies have a fuel filter? Also, a oil filter? And what is a good oil to use?
这个答案有帮助吗?
得分 0
1条评论:
Hi Ed , Here's are links to an owners manual and a service manual : http://projectmopedmanual.info/Manuals/S... ; http://projectmopedmanual.info/manuals/s... .
They are for 1980 , but all FA 50 s are pretty much identical , but for cosmetics . If you run the recommended oils , you'll have no problems .
由完成的 分享
添加一条评论
添加你的答案
Bob Bruening 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 9,159
