跳转到主内容
The HTC Inspire 4G is the first smartphone available on AT&T Wireless branded as "4G". It's nothing more then an Desire HD locked to AT&T and running AT&T Software.
12 个问题 查看全部
Can I replace just the charging port on my inspire?
I have 3! HTC Inspires all with different ailments but the most common is the charging port goes out and it wont charge anymore. I have one with a functional port but a broken screen so I would like to swap the good port to a cosmetically worthy Inspire from my “collection.”
Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Larrissa, yes you can, but you need to know how to solder. Unsolder the old port from the "most broken one" and replace the one on the phone you want to use. Or you could just get a few new ports. Those are readily available on ebay and many other places. Check this video for the disassembly. hope this helps, good luck.
这个答案有帮助吗?
得分 0
1条评论:
The mini usb port soldered onto the board can be replaced?
I thought only robots could squeeze into small solder joints like that?
Has anyone done it?..'cause I have the same problem....
完成的
添加一条评论
Here is a place you can purchase the charging port?
http://www.ebay.com/itm/HTC-Inspire-4G-C...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Larrissa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 3,421
