跳转到主内容
焊接是通过熔化另一种金属将两块金属连接在一起的方法。 焊接有很多种,但本文旨在教您电焊的基础知识。
56 个问题 查看全部
Looking to find out best means to learn soldering techniques
Hi everyone,
Looking to find information on the best means to learn how to solder. Often there are cases with my business I require the ability to solder. I have soldered previously however I find it frustrating when the solder does not stay on the part being soldered. I have read about adding flux and temperatures and a host of other articles which were not helpful.
How did you learn to solder?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
This is kind of like asking, "how do you ride a bicycle". Practice, practice, practice.
Start here: Soldering
Solder
Solder is used to create a non-permanent electrically conductive connection between non-ferrous metals. The relatively low melting point of lead/tin (Pb/SN) solder is a perfect match for sensitive electronic components. For applications where lead is not desired, one good substitute is "no lead" solder - usually a mixture of tin with a trace amount (0.3%) of copper. Note that most so-called "silver solders" are lead/tin with about 2% silver added. Lead-Free Solder
Stuff you may need: Soldering Workstation
如何焊接和拆焊
Here's some more extensive reading on it: http://www.instructables.com/id/How-to-s...
Lead-Free Solder图片
产品
Lead-Free Solder
Soldering Workstation图片
产品
$49.99
这个答案有帮助吗?
得分 3
添加一条评论
Utube
这个答案有帮助吗?
得分 0
添加一条评论
Thanks Brian.. Never thought of that..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
new2usedcomputers 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 606
