跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Washer wont' turn on?
My washer won't turn on at all. I've checked the plug, and the circuit board. I've turned the circuit off and on, unplugged and plugged the machine and now the lights don't even come on. I push the power button and it just beeps twice.
Help please
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
Was this problem ever found?
完成的
My washer wont turn on at all. It doesn't even make the clicking sound. It's just dead. It's a Kenmore series 500 HE
完成的
I am having the same problem as Debbie Cook with my Kenmore series 500 HE.
完成的
Same problem! I was doing a self clean up and after finishing the door is still lock and no power! How can I open the door with out power need to get the model number?
完成的
添加一条评论
3个答案
已选择的解决方案
Donna Giles, first try to unplug your washer and leave it unplugged for 15minutes or so, then try again. If that does not work, you may have to get a bit deeper into your washer. It is possible that the beeping originates from a failed motor control. To test that, disconnect the MI3 connector from the main control board, you access that by removing the washers top panel. If the beep stops and it programs when you press start you know you need the motor control. Download the service manual from here. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
7条评论:
Thank you Old turkey. My washer is stacked and the dryer is on top. When you say top panel, does that mean I need to take the dryer off the top or is the "top" the front where the displays are? Thanks!
完成的
Donna Giles, which washer is it? It is a Kenmore HE3? If you are using the stacking kit, then you may need to remove it. Take a look at the back and see if you can access to panel anyhow
完成的
Kenmore Elite HE3t
完成的
Looks like you'll have to remove the dryer:(
完成的
My washer is not turning on .water from my drain fell on washer and now it doesn't turn on but I can hear it turn on but no light and when I touch it it feels like it want to shock me
完成的
显示更多的2条评论
添加一条评论
Where is the M13 connector located?
这个答案有帮助吗?
得分 1
添加一条评论
Is there anyway for wires to disconnect by themselves for any reason? maybe during a power surge?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Donna Giles 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 52
总计 47,429
