跳转到主内容
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
110 个问题 查看全部
Dropped tablet. screen not cracked but colorful lines on the screen?
My galaxy tab fell onto a weight from the couch. The drop caused a dint on the back of the tablet and when I turn it on, there are colorful lines up the screen where it hit the weight. The screen is not cracked. Can this be fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 84
38条评论
I dropped my tablet on the carpet and it has colors inside the tablet and the screen is not broken
完成的
@Taylor, same answer as above but you do want to make sure that all the cables are properly seated.
完成的
My Galaxy Tab 2 10.1 fell from it's "safe" place and landed face down on the floor. It is carpeted but it is a commercial type of office carpet, so even though it isn't concrete, it was still a great impact. Just as I had feared, the display was ruined. It now has a serious vertical scroll with a split screen and colorful pinstripe lines across the top half of the screen. The tablet itself is still working fine, and I can tell by what I am able to see that the colors are just fine. I'm thinking about changing the screen to see if that fixes it. I can get a replacement screen for about $20 and it might take an hour to do the job. I think it's worth a gamble if it could potentially save me from having to fork out about $200 for a new one.
完成的
My tab inside screen is cracked and the colors are all over and the touch screen works perfect but my other tab's outside screen is cracked and my touch screen doesn't work what do I do
完成的
I have a tablet that is not cracked but the inside id white with like fingerprint marks on it. What do I do?
完成的
显示更多的33条评论
添加一条评论
3个答案
最有帮助的答案
Nesia, it would be easier if you would post an image with your question. Right now, from what you describe, it sounds like you have a broken LCD. It will cause the symptoms you describe. Check this teardown and see if you are up to replacing it. Hope this helps, good luck/
这个答案有帮助吗?
得分 3
8条评论:
My tablet's screen broke on the inside can it be fixed
完成的
@menavie yes all you have to do is to replace the display assembly
完成的
''The inside of your phone has colourful lines?.... Its because you damaged your screen at the inside need fixing try finding ones at a low price.I'm not sure
完成的
My tablet doesn't have colorful lines but the screen in cracked, do I supposed to take it to a Samsung or a t-mobile store and see if they can fix it? If they can how much it will cost?
完成的
It probably isn’t the glass or whatever material was used on the outside. It is the thing that even shows the screen (which could be a LCD, AmoLED, and you name it) that is defective.
完成的
显示更多的3条评论
添加一条评论
If you drop your tablet or phone and have lines down the screen then you need the screen replaced to sort the problem. This is to everyone who has the same issue. Repair prices for Samsung tablets aren’t as expensive as their mobiles so depending on model should be cheap enough. Stay away from network shops. O2, Vodafone etc as they won’t be much use. If you can’t do it yourself find a reputable repair shop in your area to give you a quote. Samsung tablet screen replacement is a piece of cake to be honest. Follow a few repair videos or guides and almost anyone could do it.
这个答案有帮助吗?
得分 1
添加一条评论
You need to reboot the phone if it doesn't open again its broke and it can not to be used again if it work correctly when you open the phone or tablet it will erased all of your apps and games data and photos
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nesia 将永远感激不已
浏览统计数据:
过去 24 小时: 18
过去 7 天: 95
过去 30 天: 416
总计 101,318
