跳转到主内容
Kenmore is a popular appliance brand commonly sold by Sears, but Sears does not manufacture any of the appliances themselves. Instead, they source that out and have other manufacturers make their appliances for them. Kenmore refrigerators are made by a variety of different manufacturers including LG, Electrolux, GE, and Whirlpool.
outlet trips after a while causing Refridgerator to turn off?
Hello
When I plug in my kENMORE 25361662101 it turns on and appears to be working, but then after some while it trips the outlet and turns off. I tested the outlet and its good and only have this issue when the refrigerator is plugged not with any other appliance! I realized there is no sound coming out it when plugged or turned on, (like a fan or motor? the outlet trips and doesn't stay on long enough to freeze or keep items cold. appreciate any suggestions. thank you all.
Mike H
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
5条评论
What sort of breaker is being tripped over current or earth leakage? Is the Fridge the only appliance on that circuit?
完成的
Mike H, sounds like your fridge could be drawing to many amps which will trip the breaker. How many amps on that circuit breaker?
完成的
see if you can post some images of the wiring as well as the components that you see. It is possible that you have a bad compressor run capacitor
完成的
Hello
thank you all for the questions, I m plugging in a ground-fault circuit interrupter (GFCI, it is the only appliance.
完成的
Sounds like the amp off that circuit should be okay. Take a look at the compressor and the rest of the wiring. See if there is something obvious (I still go with a bad cap first;-)
完成的
添加一条评论
4个答案
已选择的解决方案
You likely have a earth fault if the earth fault device is being tripped. Does the fridge have a butter keep in the door or other reason for wiring to go into the door? i have seen wiring in the hinge fail causing intermittent shorts to occur. The other possibility is a faulty capacitor on the compressor. With the fridge disconnected from the power measure the resistance between the earth pin and active and neutral wires. There should be an open circuit ( very high resistance). The best way to do this is with a Megger meter which will properly test the insulation/isolation between the earth and the active and neutral wires.
http://answers.yahoo.com/question/index?...
这个答案有帮助吗?
得分 1
3条评论:
I have a problem my outlite in my kitchen will stop working when this happens my fridge kicks.off the it'll kick nack.on after a hour or so
完成的
I have the same issue. There is a sound coming from the door when it's turned off the breaker. We have checked everything such as heating element and compressor and fuse as well. How can I fix the issue in the door?
完成的
We have a Kenmore side-by-side fridge (model 106. ) that will run and cool for several hours but then trips circuit breaker. Put a "3n1" start/run capacitor in it, topped off refrigerant (really didn't need it), and replaced the 20amp GFCI circuit breaker with new one (old one was 20 years old), and it still does the same thing. It takes more than five hours for the refrigerator side to go from room temperature to about 45 F but it will begin making ice within a couple of hours in the freezer side. I have noticed that along the "leading/opening edge" of the door (refrigerator side) gets very warm; but, I don't think there is any electrical wiring in that door.
My guess is that the compressor is just goin bad and the resistance is causing the issue... BUT, I am open to suggestions if anyone knows anything else that might be a simple, i.e., cheap, fix.
I replying here because this thread is related to my issue; but I'm also going to post a new thread since this one is so old. Hope that's ok.
完成的
添加一条评论
Replace the GFCI with a regular receptacle.
这个答案有帮助吗?
得分 1
2条评论:
Maybe I didn't say it right. The 10A GFCI is ON the Square D breaker in the breaker box. The receptacle itself is a regular receptacle. Someone mentioned the breaker could have gone bad and just to try replacing it with a 15A GFCI breaker. Not sure if this is a good idea, but makes sense if it was tripped for the first time in years (house is 23 yrs old) , maybe that's why it wont hold now but was working fine before the trip. I've got it with extension cord plugged into another regular circuit with regular 10A breaker and no issues leading me further to believe its just a bad GFCI breaker... ?
完成的
Normally refrigerators are plugged into 20Amp receptacles fed by a 20Amp dedicated circuit breaker to eliminate any light flickering or fluctuations on t. v. or computer screens. Yes the breaker could be bad, but to avoid future problems I would put it on a 20Amp dedicated circuit.
完成的
添加一条评论
As an Electrician I urge people not to plug the refrigerator into a GFCI.
Use a regular receptacle on a 20 amp breaker dedicated to the refrigerator.
Compressor start voltage can trip GFCIs.
这个答案有帮助吗?
得分 0
1条评论:
So I think this is the issue. It's on a 10A GFCI breaker in the Garage. It was working fine with no issues for months until I may have gotten an outside outlet on the same circuit wet or just coincidence. Now it trips immediately, UNLESS I turn the Fridge setting to 0, and plug it in. It then doesn't trip until I turn fridge setting up which I believes starts compressor. I wonder why this just started after working for months?
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike H 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 37
总计 32,698
