跳转到主内容
加入维修社区 - 创建账户
2.3L 4cyl or 3.0L V6, 6th Generation
How can I fix this problem?
my 98 accord will not shift from park to drive unless i push real hard on break pedal. can anyone help with this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
linda, it is possible that you are having issues with your gearshift-brake interlock, but since it works when you push hard on the pedal, check to see if brake lights work when applying pedal. It is possible that your brake light switch just needs to be adjusted.
这个答案有帮助吗?
得分 1
添加一条评论
i would check is your hydrolic levels low,spongy brakes,leak under car look for red fluid.
could also be bad servo unit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
linda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 187
