跳转到主内容
The Canon EOS 40D is a 10.1 MP digital single-lens reflex camera released in August of 2007.
Why is my camera's response time slow?
When I press the button to take a picture in any mode, the camera does not respond immediately. It will take a picture. It does not seem to be focusing during that time.
I've taken off the lens, cleaned the connectors and cleaned the sensor (just cause I had spots). I've charged the battery and tried a new memory card.
What else can I try before sending it in for repair?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
Is it an used or a new camera ?
完成的
I bought it in July 2008. It has been working great until I took it camping last month.
完成的
try switch cleaner on shutter switch to clean contacts cheap fix if its dirty
contacts imho
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Becky,
I found this here. Maybe it helps (although it applies to a 30D).
Steffen
这个答案有帮助吗?
得分 1
1条评论:
So I ended up sending it in for repair to the Canon Repair Center in California. They said they replaced the shutter release assembly. It is working now. I've watched a couple of youtubes with people changing this out. I think I'm glad I had professionals do it. It did cost me a couple hundred dollars; however, they cleaned it and also guaranteed the work for 6 months. I was pleased with their speed and thoroughness.
完成的
添加一条评论
添加你的答案
Becky 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 6,301
