Help to identify destroyed SMD components on MB Pro logic board
I have a late 2008 MacBook Pro 15" that needs repair. Someone was too aggressive when installing the Bluetooth/wifi/isight cable and their screwdriver or similar tool slipped TWICE (or more) and they popped two SMD components off the board. I think I have identified them as a 0.1uF ceramic capacitor and a 90ohm choke coil. If someone could verify and identify the exact models I should use to repair that would be great. I have attached two photos. One has the destroyed components circled and the other shows the board model which is a 820-2330-A.
Thanks for any help!
Here is a zoomed out picture. The components are directly in front of the isight/Bluetooth/wifi connector.
4条评论
Thanks for the help.
These are the ones I think are correct. If you can verify or let me know the correct ones if these are wrong.
Capacitor,
Choke Coil
由 fpfanatic 完成的
Yes, those parts from Digikey.com will work too. Mouser and Digikey are on top of my list for parts, but shipping sometimes bites:-)
由 oldturkey03 完成的
Got it repaired today. Working fine now. Solder paste and rework station used to do the repair. Thanks again for verifying those parts for me.
由 fpfanatic 完成的
You are welcome. Great job in getting it fixed....
由 oldturkey03 完成的
