跳转到主内容
加入维修社区 - 创建账户
PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
Unable to detect Hard Disc.
System is unable to detect Hard Disc. It was working fine last night and when started today, its showing message that Unable to find Hard Disc. I am worried for loss of data.
Please suggest me a solution as soon as possible.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Amit Lal, it is possible that your hard drive has failed or just the boot record. Set you computer BIOS to boot from an optical drive. Then use a copy of a Linux Live CD and see if you can boot from that CD. If you can, scan the hard drive and if you gain access to it, copy all the vital file to a USB drive. After that you could try to re-install the Windows OS. If your drive is not accessible, you may have to replace it and try to recover your data through some recovery software. I prefer Puppy Linux and you can do a quick search for it and copy it. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
I checked the hard disc in another laptop too, but it is not detecting. so could you tell me any way to recover the data. As I have important official data inside the hard disc.
完成的
first you need to see if you can still access the drive. Use your computer, but change the BIOS. Boot from CD and see if you have access to your drive. Use either a LINUX or a copy of Hiren's Boot CD. You will have to have access to the drive in order to copy files to a different medium, i.e. USB drive.
完成的
添加一条评论
Hi,
If you have tried testing it on other system and it is not getting detected then it must have be electronically damaged the media card which makes it next to non recoverable unless you find exact media card for disk.
Good Luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amit Lal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 426
