跳转到主内容
加入维修社区 - 创建账户
Repair guides, troubleshooting information, and service help for refrigerators manufactured by General Electric (GE).
Temperature Problems (will not cool)
I have a GE Profile refrigerator (model PSS26MSWASS) side by side refrigerator. It does not want to cool down.
I have broken it down and found that the evaporator motor was not starting. If I start in manually with my finger it will run. If I unplug it and plug it back it back in it is the same, only runs if I start it manually.
Does this mean that the fan motor is bad?
Update
Thank you again Old Turkey.
I changed the motor and it seems to be working fine now.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Rich Fahey, if by "start in manually with my finger it will run." that it will run when you start spinning it, then yes, your motor could be. It is possible that the start winding on your motor have failed (most likely), but this can also be caused by a bad start capacitor. Safest bet of course would be to replace the fan motor. The replacement part number for your fan is WR60X10185. Hope this helps, good luck.
Rotates to circulate air inside your refrigerator or refrigerator-freezer when activated.图片
产品
GE Evaporator Fan Motor - WR60X10185
$75.99
Helps start the compressor motor in your refrigerator.图片
产品
General Electric Relay Start - WR07X10084
$68.99
这个答案有帮助吗?
得分 1
2条评论:
Thank you Old Turkey . . . I will try that first.
完成的
Rich F. you are welcome. Thank you for accepting my answer.
完成的
添加一条评论
GE Profile PSB42YSNBS: I have the same issue. Evaporator fan motor stop working. Are there any DIY instructions/guide to replace it.
Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rich F 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 815
