跳转到主内容
damaged LED backlight fuse while replaced LCD
Dear Fixers,
my model a1370 srnr. DQX has a damaged backlight led fuse on the logic board, maybe someone can place a sign on the pictures i uploaded and tell me which one is the led fuse and how I replace it the best way,
lcd Panel works perfect!
thx a lot,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
HJS, this is what I found on my schematic. I would still like to triple check, so a good part number for the logic board would be great. Anyhow, you will have to solder the fuse. It is an SMD component and as such not an easy fix, but not impossible if you have some soldering experience. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
2条评论:
that`s what I expected i just needed some professional advice to go sure ;)
thx a lot oldturkey
完成的
Hey HJS
Did that component replacement work with you?
完成的
添加一条评论
添加你的答案
HJS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 10
总计 1,858
