跳转到主内容
加入维修社区 - 创建账户
一款带有大尺寸触摸屏的 GPS 导航设备。TomTom 的一体式 GPS 导航设备均包含触摸屏、扬声器、USB 接口和内置锂离子电池。
Screen does not change
My TomTom only let me choose language , than screen remains change. Does not give further option. Any answer ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Parul, try to reset your TomTom. "In rare cases, your navigation device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting.
To reset your TomTom device, do the following:
Check that the battery is charged properly.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
Remove the SD card
If your device uses an SD card, remove it.
Reset your device.
Use a straightened paper clip, or something similar, to push the reset button for at least 20 seconds. See the pictures below for where to find the reset button.
Turn your device on.
Press the On/off button for at least 5 seconds.
Insert the SD card
If your device uses an SD card, insert the SD card.
Where to find the reset button
The reset button is on the bottom of your TomTom. from here
Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Parul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 18
总计 601
