跳转到主内容
Repair and disassembly guides for Sony DVD players.
DVD player is not reading DVDs or CDs
Sony DAV-DZ690K
I own this four years old Sony Home Theatre system. I noticed recently, it is not reading either DVDs or CDs. When I insert a DVD, it takes a while to read, but shows 'No disc'. The tray simply opens on its own.
I appreciate your help to solve this problem.
Thank you so much in advance.
Narni
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
Mine takes awhile loading then says can not play this disc.
完成的
I wanted to know the spray that is used in cleaning of the lens inside the DVD
完成的
添加一条评论
3个答案
最有帮助的答案
Narni, sounds like either a dirty laser or a burned out laser. Try one of the commercially available lens cleaners. If that does not work you may have to disassemble your player and clean/replace the lens assembly. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs.
Any advise is welcome!
完成的
Thanks for the advise. I bought a lens cleaner and tried. The tray is just opening on its own. The player is not reading the discs. Any advise is welcome!
完成的
添加一条评论
Try another disc or try another drive to make sure which causes the problem. In most cases, it’s a scratched DVD or a dirty drive. This post has shown all the possible reasons and fixes.
这个答案有帮助吗?
得分 0
添加一条评论
Push power protector
这个答案有帮助吗?
得分 0
1条评论:
Push
Reasonpower protector not working
完成的
添加一条评论
添加你的答案
Narni 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 33
总计 13,891
