跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
power supply compatible parts
my power supply is buzzing, imac mid2011 27" i5 2.7ghz.
want to replace, part number should be 661-5972 but everywhere from all sellers is a picture of model 614-0446 even on ifixit(can clearly see P/N: 614... is this compatible part for all 27" iMacs? or those pictures are just for ilustration purposes?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
patrik sestak, the part number 614-0446 cross reference to the following compatibility"
iMac 27" 2.66GHz Core i5 (A1312) - Late 2009
iMac 27" 2.8GHz Core i5 (A1312) - Mid 2010
iMac 27" 2.8GHz Core i7 (A1312) - Late 2009
iMac 27" 2.93GHz Core i7 (A1312) - Mid 2010
iMac 27" 3.06GHz Core 2 Duo (A1312) - Late 2009
iMac 27" 3.2GHz Core i3 (A1312) - Mid 2010
iMac 27" 3.33GHz Core 2 Duo (A1312) - Late 2009
iMac 27" 3.6GHz Core i5 (A1312) - Mid 2010" from
The 661-5972 is definitely the right number for all Mid 2011 27" iMac's. It is available right here. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
2条评论:
i have done some research and all uk and chinesse sellers confirmed compatibility of 614-0446 with 2009,2010 and 2011 models. i wasn't sure who's right so I disassembled mine to take a look(2.7Ghz i5 mid2011). Guess what? Mine is Lite On 614-0446. Thanks for reply anyway.
完成的
That is interesting and great that you found out which one you need for sure. Hope it all works out, best of luck to you.
完成的
添加一条评论
添加你的答案
patrik sestak 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,497
