How to replace harmonic balancer on 1993 honda civic dx 1.5l
how do you replace harmonic balancer on 1993 honda civic dx 1.5l
Keith, that is one tough job that requires some tough tools. Take a look at this video
这个答案有帮助吗?
u need to take off service plate for the fly wheel at the bottom and lock the flywheel in place with a prybar or big flat screwdriver. once lock in place, use 17mm socket with 3feet 1/2in extension and 1/2in drive breaker bar. longer breaker bar u use, the easier it'll be to loosen. and just turn counter clock to loosen. when u pull out the harmonic, make sure u don't loose the small lockpin that locks pulley in place. goodluck
这个答案有帮助吗?
过去的24小时: 1
过去的7天: 2
过去的30天: 8
总计 2,545
