跳转到主内容
电脑显示器维修。
How to fix lcd monitors with psu problems?
i would like instruction to fix monitor in general, with mainboard problems or power supply issue, etc.
how do diagnost them
thxs
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
My old Hazro 2K Monitor( bought 2011) has just stopped working . I think it is the power supply because the fuse is ok, but the LED on the PSU is off. Can I use any 24V 5A (120W) PSU to test it?
完成的
添加一条评论
1个答案
已选择的解决方案
Gabriel barrandeguy, this is a very broad question and most certainly will be difficult to answer. Always remember that any LCD monitor in general has all the same parts. You have your power supply, most of those having the inverter circuitry on the same board, your video board, your LCD panel and your button bars. Then there are those that have a few other things, like speakers, additional USB ports etc. Most common issues that I found, are power supply issues, with capacitor failure being the number one issue. Bad capacitors are most of the time visually identified by a domed top, or even leaking capacitor. As a rule of thumb, I always change all the capacitors. [http://Check here] for a more visual guide. I believe that Samsung has the greatest rate of failure on the power supply. Most monitors do a self test and have the power light blink a certain error code. This will be monitor specific. As a rule of thumb for myself, I found that if the power light is on, and it does not flash in a specific pattern, and the monitor does not have a clearly visible picture, the error is most likely a bad backlight. All the monitors I've worked on have the backlight circuitry on the power supply board. I have only had very few monitors with failed CCFL in the LCD itself. There are many ways of testing a monitor to determine what has failed. To properly troubleshoot a monitor, I try to get the service manual as well as the datasheet for the display panel. A working knowledge of test equipment like, at minimum a multimeter is necessary. I now use a backlight tester, a multimeter and a transistor tester for the MOSFET on a PSU.
这个答案有帮助吗?
得分 2
2条评论:
thxs for your reply.
can u give me url from amazon to buy a blacklight tester and the other things you suggest.
i would like instruction to test, mainboard, backlight, screens , powersupply (it is what i found the most just changing capacitors)
thxs in advance
完成的
Again, those are really hard to group together. Each monitor has its own specific part, layout etc. You can get a fancy LCD tester from here http://www.lcdparts.net/LST.aspx or check on ebay for some cheaper ones. email me for some more detailed information on LCD repair.
完成的
添加一条评论
添加你的答案
Gabriel barrandeguy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 32
总计 7,016
