跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
How can I get my iPod Classic to Restore? Nothing works!
When I plugged my iPod into the computer this week, iTunes tells me it is corrupted and needs to be restored. When I attempt to restore it, it tells me that it can't be restored and gives me error code "1439." I have installed the newest iTunes and have repeated this process many times. I have tried different USB ports and cords. I have a PC (with Windows Vista) and when I put my iPod in "disc mode" and went to it's properties, it also will not restore. Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 10
4条评论
What properties did it show you when you were in disk mode?
完成的
I tried the solution below with no success. When I am in Disk Mode on computer (Computer>(My iPod)>Properties), It says that I have 148 GB (out of 160) available, but the pie charts say that I have 0 Bytes used and 0 Bytes free? Extremely odd! When I try to error check, it says that Windows cannot access the disk
完成的
your hard drive is dead.
完成的
Hello I have tried to restore my ipod classic but itunes keeps indicating that my ipod is corrupt
完成的
添加一条评论
2个答案
最有帮助的答案
Mikayla try this from Apple. It is the same for error 50 but could work for 1439 as well:"
Disconnect the iPod from the computer and close iTunes.
Highlight all of the following 10 lines of text that begin with regsvr32 and then choose Copy from the Edit menu of your web browser:
regsvr32 /s softpub.dll
regsvr32 /s wintrust.dll
regsvr32 /s dssenh.dll
regsvr32 /s rsaenh.dll
regsvr32 /s gpkcsp.dll
regsvr32 /s sccbase.dll
regsvr32 /s slbcsp.dll
regsvr32 /s mssip32.dll
regsvr32 /s cryptdlg.dll
regsvr32 /s initpki.dll
Open the Notepad program by navigating to:
Start > All Programs > Accessories > Notepad
In Notepad, choose Paste from the Edit menu. Note: Make sure that the text that appears in Notepad is the same as what is shown above.
From the File menu, choose Save As.
For File name, type appleipod.bat and save the file to the Desktop.
Close Notepad and locate the appleipod.bat file. It should appear on the Desktop
Double-click the file and you will see a black window appear on the screen for about a minute. Wait until the window automatically disappears and proceed to the next step.
The appleipod.bat file can be deleted at this time.
Open iTunes and connect the iPod.
When the iPod appears in iTunes, restore the iPod and resync your content.
Note: Because some malware may unregister the .dll files, make sure you have the most recent updates to your anti-virus software and then do a full scan of your files.
Update
If the above does not work and you get the "It says that I have 148 GB (out of 160) available, but the pie charts say that I have 0 Bytes used and 0 Bytes free" sounds like you have either a bad hard drive or a bad hard drive cable. I would check the hard drive with a Zif-to USB connector.
这个答案有帮助吗?
得分 9
15条评论:
Thank you so much! Had tried just about everything to no avail. This finally worked!
完成的
This absolutely brilliant, clear concise and effective. I ve been all over the web this is the only thing that worked!!!
完成的
still didnt worked fuh me and i did everything step by step
完成的
Amazing answer. I tried everything and only this worked, i was having the same problem with my ipod, also showing it as 148 gb when it is in fact160 gb and was unable to restore it until I tried this. THANK YOU SOOOOO MUCH!
完成的
I tried everything I could find and this was the only thing that fixed my iPod classic! Thank you!
完成的
显示更多的10条评论
添加一条评论
I feel your frustration, had same situation with iTunes.
After very long hours of trying everything short of reinstalling Windows, I found a solution that worked for me:
replaced softpub.dll in both System32 AND SysWOW64. Et voila! Done.
I'm assuming this is valid for all things Apple, as I have seen literally hundreds of posts. Hope this also solves your predicament.
这个答案有帮助吗?
得分 1
3条评论:
Replaced them with what?
完成的
Use EaseUS Partition Master Home Edition (Free) and format as FAT32 with 128k clusters. After this restore works well.
完成的
@setfreen This worked like a charm. Thanks.
完成的
添加一条评论
添加你的答案
Mikayla 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 45
总计 38,517
