Where exactly is the Flasher Relay for a 2003 Mazda Protege located?
Berry, the Turn signal/Flasher relay is under dash on drivers side. If you have a manual transmission is is almost directly above the clutch pedal. It is a gray colored box about 2 inches wide by 4 inches long. It is #5 in the attached diagram.
Hope this helps, good luck.
这个答案有帮助吗?
Thank You very much , it solved my problem.
Thanks
Ronald (Philippines}
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 38
总计 10,992
1条评论
Thanks oldturkey03! I will check this out immediately.
由 Berry 完成的
