broken left-hand hinge between body and screen
Hi, is it possible to buy a left-hand hinge to replace the broken one which has broken somehow and come out of the screen's lower edge?
Unfortunately the hinge on a Titanium is part of the screen assembly, and it's not possible to swap out a left hinge or a right hinge -- you'll need to replace the whole display assembly, screen, hinge, cabling, and all. Technically it is possible to transplant your screen into another casing/hinge/bezel, however I've found that removing the bezel from a Titanium effectively destroys it, so replacing the whole thing is really the only way to do it without pulling your hair out in the process.
I'd recommend buying a dead Titanium on eBay that has a good screen and hinge. Just make sure to buy one from a machine that has the same model number and processor speed, because there are at least a couple versions out there and it would be a bummer to end up with one that has the wrong video cable.
Another note -- if you current screen is working, you can make up for the cost of the above purchase by stripping off the bezel/casing/hinge and selling the screen itself on eBay as a working bare screen. There are a number of 15" laptops out there which use that screen, and, who knows, you might end up making money at the end of the day.
Also, taking apart a Titanium to the degree necessary for screen replacement is one of the more difficult procedures out there, and many who have taken it on have sworn to never do it again. I'm not trying to discourage you, but if it's not too bad, you may want to consider just putting up with it.
这个答案有帮助吗?
Agreed +
If you like your Titanium and really want to repair it you can find the hinges on ebay. Also replacing the hinge doesn't mean that you have to completely separate the bezel from the display (I agree with rdklinc, it could damage it) but only split the bezel in the hinge area enough to remove the broken hinge and insert the new one so again you don't have to completely take apart the bezel from the display. If you do a search on youtube, powermedic.com and many other places you will surely find a tutorial that will guide you cause Titanium broken hinges and repair is a well documented subject on the web. Good luck...
这个答案有帮助吗?
Good answer + Ralph
Very cool! I never realized the hinges were removable. I just found one on eBay new for...gasp!...$75?!?!?! A dead machine may still be the best way to get the parts. And regardless, unfortunately it's still a really tough repair job to get the screen assembly off the laptop (you have to remove the logic board before you can remove the screen). But at least that makes it slightly easier.
$75 is a rip off. You have to check often on ebay to find a reasonable price. Also, you don't have to remove the display from the bottom case to replace the hinge if the cables are not damaged.
what screwdriver on your tools list will remove the hinge screws? Can I epoxy the broken screen part?
这个答案有帮助吗?
Please start a new question. What broken screen part?
Josh, yes I purchased the Hinge from I fixit (lowest cost). I am still looking for a local Mac tech that has done this hinge replacement OR is willing to do it. I also contacted a company in Brooklyn NY that sells special epoxy (suggested by Mayer). If I had both hinges broken I might be reluctant to repair verse replace Good luck
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 1,527
