跳转到主内容
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Repair Manual for Craftsman Riding Mower
How can I obtain a repair manual for a Craftsman Riding Mower?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 51
26条评论
Depends on what model your mower is:-)
完成的
The model number is 917.2736403
Why would not all the Craftsman riding mowers have repair manuals available?
完成的
I am sure they all do, but some off those need to be purchased through Craftsman and/or the dealers while others are downloadable.
完成的
why would oil be coming from the exhaust
完成的
why would oil be coming from the exhaust on my LT 1500
完成的
显示更多的21条评论
添加一条评论
3个答案
已选择的解决方案
Leon, download the manual from here. It has the user manual as well as the tractor repair manual in the back. If you are looking for something more specific, let us know. Any engine repair etc, will require the service manual from the engine manufacturer, i.e. B&S etc. Hope this helps, good luck.
Update (05/29/2022)
Difficult to keep manuals online for 9 years. It is now posted on the bottom of this page Craftsman Riding Mower as "Craftsman_917_2736403_DYT 4000"
这个答案有帮助吗?
得分 16
21条评论:
Need a manul for a Craftsman LT1750 Limited Edition riding mower with Koehler 17 1/2 power engine
完成的
Manuals Lib.com
完成的
log onto / Manuals Lib.com
完成的
need service & repair manual for craftsman tractor 917.258691
完成的
Need a deck for 917.272011
完成的
显示更多的16条评论
添加一条评论
I have a t140 craftsman riding mower.I took off the drive belt pulley assemble. I can not find how to put back on tractor. When I put together the belt will not disengaged with the motor running. I cannot the find adjustment on this t140 tractor. This only has two (2) pulleys NOT (3) pulleys.
This unit has left pedal which disengage the belt and brake. The right pedal only drive the unit. The more you push the pedal down the faster it will travel.
这个答案有帮助吗?
得分 0
1条评论:
A shop manual will help a lot.
完成的
添加一条评论
MTD makes many rebadged tractors including Craftsman. Search for craftsman tractor manual or MTD tractor manual and find one the looks similar. Most drive belt arrangements will be the same. My Troybilt has and idler pulley that tightens/loosens the belt. There are 4 pulleys, one on each blade drive, one on the motor and the idler. I can't picture how a 2 pulley system would work.
If you can't find a manual, you might also search parts stores for part diagrams.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Leon 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 155
总计 59,582
