跳转到主内容
Why won't my iPod connect to my mac?
I had the motherboard replaced yesterday but now it wont connect at all to my mac. Tried every usb port and it won't even show up in disk utility. Plugged it into a wall socket and it charges as well as using multiple cables
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
joberteugenio, if it does charge on an AC charger but not your USB port could be related to a bad battery (Your AC adapter supplied a higher amperage than your USB ) or a bad dock connector (since you already changed the cables and the USB ports on your computer) I would double check with the place that replaced your logic board to make sure this is not something related to the workmanship. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
joberteugenio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 168
