Turn off oil change warning
I have changed my my oil in my 2012 Jeep Wrangler but now I need to know how to turn off the Oil Change warning that appears every time I start the engine.
1. Turn the ignition switch to the ON position (Do not start the engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
这个答案有帮助吗?
I'm not positive, but you probably need an OBDII reader of some kind. I have one that plugs in to my iPhone and uses an app called "DashCommand" to read and clear codes and warning lights, but there are many standalone units that also will solve your problem.
这个答案有帮助吗?
过去 24 小时: 24
过去 7 天: 135
过去 30 天: 642
总计 12,373
1条评论
It did not work on my 2008 Rubicon.
由 Baker311 完成的
