跳转到主内容
These repair guides are for a 2007-2012 Jeep Wrangler (JK) Sport, Sahara, Rubicon and Unlimited Editions.
22 个问题 查看全部
Turn off oil change warning
I have changed my my oil in my 2012 Jeep Wrangler but now I need to know how to turn off the Oil Change warning that appears every time I start the engine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
1. Turn the ignition switch to the ON position (Do not start the engine).
2. Fully depress the accelerator pedal slowly three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
这个答案有帮助吗?
得分 3
添加一条评论
I'm not positive, but you probably need an OBDII reader of some kind. I have one that plugs in to my iPhone and uses an app called "DashCommand" to read and clear codes and warning lights, but there are many standalone units that also will solve your problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kim 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 93
总计 8,635
