跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
How to remove broken display
I have great problems getting the display released from the phone after removing the two pentalope screws.
When the display is broken I can not get a vacuum formed under my suction cup and get the display lifted.
Surely there most be some great tips for solving this. Any suggestions from you guys?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
6个答案
已选择的解决方案
there is a plastic frame around the glass.
i use a dental pick to pry in the plastic and pull the screen up.(start at the bottom) be sure not to touch the aluminum frame. as it will dent very fast. as soon as you pull it high enough you will create a little gap. insert a plastic guitar pick. this can be a little tricky using only 2 hands.
insert a second guitar pick and slide it along the edges..
this is for me the easiest way to remove a broken screen without damaging the oh so fragile ;-) back cover
have a nice repair
这个答案有帮助吗?
得分 1
1条评论:
Hi both
Thank you for your responses. I will try them both and let you know how it goes.
完成的
添加一条评论
最有帮助的答案
martin, I use some really sticky duct tape to pull it of.
这个答案有帮助吗?
得分 2
添加一条评论
I put a piece of clear packing tape over my cracked screen to get the suction cup to work. It's really quite tight, the guitar pick is a great idea.
这个答案有帮助吗?
得分 1
添加一条评论
Clear packing tape worked great, thanks for the tip!
这个答案有帮助吗?
得分 0
添加一条评论
Using scotch tape, you can lift LCD successfully.
这个答案有帮助吗?
得分 0
添加一条评论
Bottom left of the phone insert a pointy pry tool there is a gap on the screen itself
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
martin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 19
总计 5,683
