USB Port Not Working
Hello, I have a USB port not working. I dropped my macbook and it doesn't work anymore. Can the USB port be replaced by itself or does the entire logic board have to be replaced?
The USB port is built into the logic board. If you are trying to use a device that pulls power from it, it may not work if the battery is down and it is not plugged it.
这个答案有帮助吗?
That's what I mean. I can't pull power from it. Does the entire logic board have to be replaced to fix it? Or is there a way to just replace the port. Thinking soldering might be required but I'm not sure.
Will it work on the other USB port?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 700
1条评论
Hi.. did you find any solution to it.??
由 jayaram 完成的
