跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
MacBook does not work on AC power
MacBook stopped charging the battery and will not work with AC power adapter only.
MacBook notices the connected power adapter, but reports battery not charging. Adapter light stays green even when battery needs recharging. MacBook runs fine on battery power. Installed battery update 1.4. Checked the battery (Cycles 66, Condition: good; does charge on onther MacBook). Checked the AC adapter (works fine on other MacBook).
Logic board failure?
Any other thoughts?
Update
got no applecare for this MacBook.
read somewhere a faulty connector could be covered by legal product warranty (production fault)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Since it works with the battery and not the adapter probably the magsafe board is bad. I'm including the url's for the repair and the part. Ralph
MacBook Core 2 Duo Magsafe Board Replacement
MacBook MagSafe DC-In Board
这个答案有帮助吗?
得分 1
1条评论:
Agreed. + I would also try using some contact cleaner on any corroded surface.
完成的
添加一条评论
最有帮助的答案
Power flows from the AC adapter, to the DC-in board, through the logic board and battery connector, then finally to the battery. There obviously isn't anything wrong with the battery or the AC adapter because they work on a known good machine. Therefore, it is something internal.
I would suggest opening the computer and checking the battery connector first. There have been a quite a few computers I have worked on and there was some corrosion in between the battery connector and the logic board. If there is then you need to replace the logic board and then battery connector.
Hopefully there isn't any corrosion and you can just replace the DC-in board.
Goodluck!
MacBook MagSafe DC-In Board图片
产品
$19.99
这个答案有帮助吗?
得分 1
添加一条评论
follow up:
re Jethro:
- is the DC-in board (only) a connector, or does it contain electronics ?
- visual inspection of the battery connector shows no corrosion.
re Ralph:
- if the DC-in board is a connector only, I find it hard to believe this can malfunction.
- if so, can a claim for repair be covered by an (extended) applecare warranty ?
MacRuud
这个答案有帮助吗?
得分 0
1条评论:
If you still have AppleCare and it hasn't gotten wet, take it in. Come back here after the warranty has expired.
完成的
添加一条评论
添加你的答案
MacRuud 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 2,669
