跳转到主内容
Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
How can I replace the flex?
The computers boots up. However, the screen turns on and off rapidly or doesn't turn on at all. The problem is independent of the position of the screen.
EDIT: Using a flashlight I realised that you can barely se the screen. So the problem is the backlight.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
simon, exactly what flex are you trying to replace? the reason for not having a backlight could be a bad inverter, a bad LCD, a bad Lid swithc or even a failed backlight circuit (common failure on this model) it is under the right side hinge. "However, the screen turns on and off rapidly or doesn't turn on at all" sounds more like a broken backlight cable or a failing switch.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
From what you are describing it is possible the flex cable is damaged as it carries power to the inverter for the back-light however it could also be a faulty inverter board.
The cable and inverter can be purchased for around $30 so perhaps just replacing both may be the best approach.
Inverter replacement video
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
simon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,322
