跳转到主内容
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
How to Set the Clock on a 2002 dodge ram
I am having problems with the radio clock, I had to remove the battery and it changed the time. I dont know how to set the time on the clock.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I got a 2007 dodge ram how to set the clock time
完成的
添加一条评论
4个答案
已选择的解决方案
leonel, for the standard radio you should turn the radio on, then press the "Setup" key, the hour will flash. Turn the station control knob left (ahead) or right (back). Then press the station control knob and the minutes should flash. Then turn the control for station again and this should set your time. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
1条评论:
Followed directions to the letter. No go.
完成的
添加一条评论
Could be diferent on each car. I had 2 little buttons on the right side said H & M use a pen to press them.
Sorry for the grammer i am dutch.
这个答案有帮助吗?
得分 1
2条评论:
Worked for me.
完成的
That did the trick, Dodge ram 1500 from the 2000'
完成的
添加一条评论
You have to turn off the radio, then press and hold the time button until the clock flashes, then use the tunning control to adjust the time. Then press the time button again to finish.
这个答案有帮助吗?
得分 1
1条评论:
The hour flashed but I couldn't get the minutes to flash
完成的
添加一条评论
Old thread but figured it would help, I didn't know either Push in on the tune knob to change to minutes
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
leonel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 55
总计 43,961
