跳转到主内容
加入维修社区 - 创建账户
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
Click wheel still not working?
One day in my school bus my iPod fell and it was working after that i didn't use it for months, then suddenly i tried setting it on well the click wheel didn't work at that time so i tried to replace the click wheel. After a successful click wheel repair, i tired turning it "on" still it doesn't work.
Please help me?
I read online and it seems that i have to replace the mother board. Is it true?
Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Karan Bindal, you do want to make sure that your properly connected your click wheel. Check the connector on the logic board and make sure that the click wheel is inserted all the way and straight. If it is, then it is possible that you have a bad click wheel, replace it again, or a broken logic board. Make sure that your hold switch is in the off position. A iPod that is locked by the hold switch will also leave your click wheel as non-operational. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Karan Bindal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 142
