跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Water Damage - Touch screen on iPhone not working and black screen?
Hello! I dropped my iPhone 4 about 5 months ago in water. So now I want to bring it back to life. When I charge the iPhone it turns on and makes the sound when it boots up. However I am not being able to see the video, but a black dim light is produced. Also the touch screen does not work since I can't unlock the phone. All I seem to be able to do is call on Voice control and tell it to do tasks. Please help me, I have already taken it to someone who might be able to fix it, and they told me the motherboard had corrosion from the water. But I really know that I don't have to change the whole motherboard, I'm sure it is one or two parts that need to be changed. Thank you! This is such a great website!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Renato Espinel, there is the possibility that it is only "one or two parts that need to be changed", but right now time is against you. the very first thing you want to do is to totally disassemble your phone. For that I would use this guide. Once you have it disassembled, you do want to clean the logic board. For that part of the job, follow this guide. Depending on the amount of corrosion, you may have to do it a few times. Take your time and be diligent about cleaning it. Check the board for any missing or damaged components. Do not forget to clean the dock connector. Once you have it cleaned, replace the battery and then re-evaluate for any damage and repair those one at a time. Hope this helps, good luck.
iPhone 4 主板图片
指南
iPhone 4 主板更换
难度:
困难
30 minutes - 2 hours
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
这个答案有帮助吗?
得分 2
添加一条评论
Well it sounds like the mobo to me. You can try to clean the corrosion but if its been sitting that long it will probably need to be replaced.
Good Luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Renato Espinel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,822
