跳转到主内容
加入维修社区 - 创建账户
Audio Jack doesn't work. How to replace?
I have a problem with the headphone audio jack, does not always work properly, can i replace the single part, or i have to change the logic board?
Thanks
Lorenzo
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Lorenzo Maggiorotti, the connector is soldered onto the logic board. Costly undertaking to replace the complete board for that, so you might consider having someone try and fix it for you. It is not an easy DIY'er job, but somebody with the right tools and th right experience might be able to handle it. Apple part number for the connector is 514-0671 and it is defined as a SPDIF-TXRX-K24, looking at the diagram, it seems to be a standard connector. So a good search may find you a replacement.
Hope this helps, good luck.
这个答案有帮助吗?
得分 1
3条评论:
oldturkey03, any clues on how to fix it if it's not broken, but just a little loose? slight movement pulls the plug out of the jack now on mine.
完成的
any chance you could solder it:-)
完成的
My audio connector is not working. This is what I've been doing to solve the problem :)
http://www.walmart.ca/en/ip/usb-to-stere...
完成的
添加一条评论
添加你的答案
redacted 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,325
