跳转到主内容
A 4GB 3.6" Touch Video MP3 Player by Sylvania.
Why won't player turn on?
I have tried over and over again to turn my player on. I have tried charging it several times and have even tried the reset button, but it will not come on. It was working fine, then I started downloading some more music when it shut off and would not turn back on. My laptop recognizes that it is pluged up. I only have a USB cable to charge it and I have even tried three different USB ports on my laptop. What is the cause and fix for this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
henryr79, it does sound like a battery failure. If it has discharged to below its threshold it will no longer accept a charge or hold a charge. I would start with that. Follow this teardown to change your battery and re-evaluate. hope this helps, good luck.
这个答案有帮助吗?
得分 2
2条评论:
What does a battery cost and where can one be bought?
完成的
Once you have it apart, there should be a number on the battery. Use that to do a search according to your location.
完成的
添加一条评论
It was not working and how to fix it.
这个答案有帮助吗?
得分 0
1条评论:
Um... what are you talking about???
完成的
添加一条评论
My sony walkman wont turn on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
henryr79 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 2,793
